Hello, maybe I'm a bit silly for not figuring this one out on my own. Is there no way to utilize AI chat features on property or parameter binding transforms? I can clearly see how to prompt for direct bindings (expressions can easily be optimized), but I personally very frequently use an expression binding with a script transform, and I just don't see a clear way to prompt for the script transform.
The entire way you use Catalyst within Perspective is undergoing revision; we're not 100% sure what the "final" shape will look like, but it will definitely be different (and more capable) by the final release. We'll probably make some kind of announcement once it's going out in an upcoming beta release.
I assume an AI helper in the AI tool script window is also on the way ?
I also saw a perspective view AI helper in the ICC videos but that seems to be missing ?
Yes, this should be available in the next release.
Not missing, just not shipped yet; see above.
Depending on which video you're referring to, you might also be mixing up use of the AI Chat component inside Perspective, which can drive property changes and therefore "configure a view" via edits to the dashboard component.
