Hello,
When I create a table and populate it with SQLTag history and then want to modify the table dataset, I always have an error.
Need to quit the project (open another one) and come back.
Very anoying…
Any idea ?
[quote]java.lang.NullPointerException
at com.inductiveautomation.ignition.designer.sqltags.dialog.HistoricalTagBrowserPanel$TagPathRenderer.setValue(HistoricalTagBrowserPanel.java:212)
at javax.swing.table.DefaultTableCellRenderer.getTableCellRendererComponent(DefaultTableCellRenderer.java:237)
at javax.swing.JTable$AccessibleJTable.getAccessibleChild(JTable.java:7023)
at javax.swing.JTable$AccessibleJTable.getAccessibleAt(JTable.java:7410)
at javax.swing.JTable$AccessibleJTable.valueChanged(JTable.java:6923)
at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:167)
at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:147)
at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:194)
at javax.swing.DefaultListSelectionModel.changeSelection(DefaultListSelectionModel.java:388)
at javax.swing.DefaultListSelectionModel.changeSelection(DefaultListSelectionModel.java:398)
at javax.swing.DefaultListSelectionModel.removeSelectionIntervalImpl(DefaultListSelectionModel.java:559)
at javax.swing.DefaultListSelectionModel.clearSelection(DefaultListSelectionModel.java:403)
at javax.swing.JTable.clearSelection(JTable.java:2081)
at javax.swing.JTable.clearSelectionAndLeadAnchor(JTable.java:2088)
at javax.swing.JTable.tableChanged(JTable.java:4433)
at javax.swing.table.AbstractTableModel.fireTableChanged(AbstractTableModel.java:280)
at javax.swing.table.AbstractTableModel.fireTableDataChanged(AbstractTableModel.java:182)
at com.inductiveautomation.ignition.designer.sqltags.dialog.HistoricalTagBrowserPanel$TagPathModel.filter(HistoricalTagBrowserPanel.java:171)
at com.inductiveautomation.ignition.designer.sqltags.dialog.HistoricalTagBrowserPanel$TagPathModel.refresh(HistoricalTagBrowserPanel.java:180)
at com.inductiveautomation.ignition.designer.sqltags.dialog.HistoricalTagBrowserPanel.resetSearch(HistoricalTagBrowserPanel.java:110)
at com.inductiveautomation.factorypmi.designer.property.configurators.TagHistoryConfigPanel.init(TagHistoryConfigPanel.java:182)
at com.inductiveautomation.factorypmi.designer.property.configurators.TagHistoryConfigurator.init(TagHistoryConfigurator.java:51)
at com.inductiveautomation.factorypmi.designer.property.configurators.ConfiguratorMultiplexor$EditorParent$1.run(ConfiguratorMultiplexor.java:153)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:633)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:205)
at java.awt.Dialog$1.run(Dialog.java:1046)
at java.awt.Dialog$3.run(Dialog.java:1098)
at java.awt.Dialog.show(Dialog.java:1096)
at java.awt.Component.show(Component.java:1563)
at java.awt.Component.setVisible(Component.java:1515)
at java.awt.Window.setVisible(Window.java:842)
at java.awt.Dialog.setVisible(Dialog.java:986)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.showDialog(DynamicOptsDialog.java:177)
at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.openBindingDialog(VisionDesignerImpl.java:551)
at com.inductiveautomation.factorypmi.designer.property.editors.bb.DynamicOptionsButton.actionPerformed(DynamicOptionsButton.java:36)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2028)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2351)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
at com.jidesoft.plaf.basic.BasicJideButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:272)
at java.awt.Component.processMouseEvent(Component.java:6352)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6117)
at java.awt.Container.processEvent(Container.java:2085)
at java.awt.Component.dispatchEventImpl(Component.java:4714)
at java.awt.Container.dispatchEventImpl(Container.java:2143)
at java.awt.Component.dispatchEvent(Component.java:4544)
at javax.swing.plaf.basic.BasicTableUI$Handler.repostEvent(BasicTableUI.java:918)
at javax.swing.plaf.basic.BasicTableUI$Handler.mouseReleased(BasicTableUI.java:1134)
at com.jidesoft.swing.DelegateMouseInputListener.mouseReleased(Unknown Source)
at com.jidesoft.grid.TreeTable$DelegateExpandMouseInputListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:273)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4621)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4282)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4212)
at java.awt.Container.dispatchEventImpl(Container.java:2129)
at java.awt.Window.dispatchEventImpl(Window.java:2478)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:635)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Ignition v7.2.0 (b6498)
Java: Apple Inc. 1.6.0_22
[/quote]
