While trying to delete a tag folder containing tags in the designer using the right click dialog I get the following error message
[code]com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Gateway Error 60001
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:283)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:253)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:214)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:699)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.removeTags(DatasourceTagManager.java:373)
at com.inductiveautomation.ignition.client.sqltags.impl.ClientTagManagerImpl.removeTags(ClientTagManagerImpl.java:303)
at com.inductiveautomation.ignition.designer.sqltags.util.TagUtilities.removeTags(TagUtilities.java:244)
at com.inductiveautomation.ignition.designer.sqltags.dialog.TagBrowserPanel$TagBrowserActionHandler$DeleteTask.run(TagBrowserPanel.java:478)
at com.inductiveautomation.ignition.client.util.gui.progress.ClientProgressManager$ClientRunningTask.run(ClientProgressManager.java:544)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:526)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NullPointerException
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.getDBId(InternalTagStore.java:199)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.deleteTagsBatch(InternalTagStore.java:732)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.deleteTags(InternalTagStore.java:692)
at com.inductiveautomation.ignition.gateway.sqltags.providers.AbstractStoreBasedTagProvider.removeTags(AbstractStoreBasedTagProvider.java:547)
at com.inductiveautomation.ignition.gateway.sqltags.providers.RedundantProviderWrapper._removeTags(RedundantProviderWrapper.java:82)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.inductiveautomation.ignition.common.messages.ReflectiveInvokeMessage.execute(ReflectiveInvokeMessage.java:41)
at com.inductiveautomation.ignition.gateway.sqltags.providers.RedundantProviderWrapper$ConfigRedundancyMessageListener.receiveCall(RedundantProviderWrapper.java:190)
at com.inductiveautomation.ignition.gateway.cluster.QueueableMessageReceiver.receiveCall(QueueableMessageReceiver.java:45)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.dispatchMessage(RedundancyManagerImpl.java:619)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl$ExecuteTask.run(RedundancyManagerImpl.java:640)
… 9 more
Ignition v7.3.3 (b570)
Java: Sun Microsystems Inc. 1.6.0_07
[/code]
I can submit my tagdatabase if need be
