Alarm description and priority are not being called correctly by the alarm status table (shows display path and low priority irrespective of actual value) when used in a UDT. Works fine when it triggers off a stand alone tag.
Any suggestions.
This all worked fine before, but did a firmware update to the processor and seems to have screwed things up (or a version issue with ignition)
Using ControlLogix v21+ now.
