V7.9.1 Reporting- Schedule, Run Script dataMap Contents
Hi Guys,
I cant seem to find any documentation that clearly defines what information you can get from the Reporting Modules Schedule Run Script “dataMap” Argument.
Was hoping that you can retrieve values from a Data Source (SQL Query) instead of just Parameter Values? If it is possible could you show an example?
Cheers
Tim…
Did you see the example in the docs?
Thanks Kathy,
Got it using the getCoreResults from the dataMap
cheers :thumb_left:
The link is not working. Please give some example docs for using DataMap for 8.1. Thanks.
