V7 Global Resource Change Log
v7.9.9
I’m looking to see what global resources have been edited in a log, similar to the project details log in the gateway webpage example below:
Is something like this available for the global resources?
I’m guessing this isn’t captured anywhere?
No, it’s not, though the new auditing stuff may capture similar information. @paul-griffith?
All project changes are audited in 8.0, as of 8.0.5 or .6, yeah. For 7.9, I imagine you technically could enable auditing on the global project, but as there’s no way to open the UI for editing I’m not sure how you actually would.
Oops, I misread / misunderstood this post as being about getting similar information in Ignition 8.
Do you know how to manually get to the internal database in the UI? I imagine you could select * from project_changes where projectid=-1; I have to assume that we're using the same mechanism to store all project changes and not specifically discarding the global project, although that may be a poor assumption.
Awesome, this works :slight_smile: Cheers!
I'm guessing I can use SELECT * FROM SQLTAG ORDER BY SQLTag_ID DESC for the tags, albeit it's not as convenient without the date added field.
