Hello,
Having issues browsing UDT tag members in the designer (instance does not expand/drop down) – getting this in the logs:
core 12Jun2019 13:03:43 Error browsing tag '[default]Overview/_1985FN31074'
java.lang.ClassCastException: Error trying to coerce '(ns=1;s=[a0006_s00]_1985fn31074.cfg_hasspeedfdbk)' to a number.
at com.inductiveautomation.ignition.common.TypeUtilities.toNumber(TypeUtilities.java:728)
at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:1027)
at com.inductiveautomation.ignition.common.TypeUtilities.toInteger(TypeUtilities.java:1427)
at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:1020)
at com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.ExecutableTagPropertyModel$BoundProperty.getRaw(ExecutableTagPropertyModel.java:317)
at com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.ExecutableTagPropertyModel.getImpl(ExecutableTagPropertyModel.java:101)
at com.inductiveautomation.ignition.common.config.AbstractExtendedPropertySet.get(AbstractExtendedPropertySet.java:69)
at com.inductiveautomation.ignition.common.config.PropertyValueSource.getNonNull(PropertyValueSource.java:68)
at com.inductiveautomation.ignition.gateway.tags.runtime.nodes.BasicTagDefinition.shouldBeEnabled(BasicTagDefinition.java:269)
at com.inductiveautomation.ignition.gateway.tags.runtime.nodes.BasicTagDefinition.getBrowseInfo(BasicTagDefinition.java:280)
at com.inductiveautomation.ignition.gateway.tags.runtime.nodes.FolderNode.browse(FolderNode.java:123)
at com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.AbstractComplexTagNode.browse(AbstractComplexTagNode.java:74)
at com.inductiveautomation.ignition.gateway.tags.runtime.nodes.BasicTagDefinition.browse(BasicTagDefinition.java:327)
at com.inductiveautomation.ignition.gateway.tags.runtime.TagEvaluationManagerImpl.browse(TagEvaluationManagerImpl.java:86)
at com.inductiveautomation.ignition.gateway.tags.TagProviderImpl.lambda$browseAsync$5(TagProviderImpl.java:420)
at com.inductiveautomation.ignition.gateway.tags.TagProviderImpl.lambda$exec$2(TagProviderImpl.java:345)
at java.base/java.util.concurrent.CompletableFuture$AsyncSupply.run(Unknown Source)
In the designer output console:
13:08:32.631 [AWT-EventQueue-0] WARN com.inductiveautomation.ignition.client.tags.tree.node.AbstractBrowseNode - Node[Overview] was asked for child 6 while status=LOADING.
Any ideas/help would be greatly appreciated… I understand that there may be some issue with this “Cfg_HasSpeedFdbk” tag – but should it really prevent me from browsing?
Thanks!
-Paul
