[size=150]Hello,
I’m having a problem sending values to a MSSQL Database.
The DB state is “Valid” in the gateway but It’s faulted in the Designer and Client.
I moved to the Designer to add the DB as Default in the Project Proprieties, then I tried to Store history for a Tag, but the object that used to have the Tag implemented gets an error.
What can cause this problem? The Database is located on another server that I’m acessing through a VPN Client. [/size]
[size=150]Thank you!
[/size]
