Hi
I’m having issues with passing messages up from Embedded Views.
I’ve built a little standard Sites dropdown box in a project called CORE, to select which site to look at. I’ve put an onchange script on the value prop, so that it gets called when someone changes the site selection (with the idea that I could pass a message up to the Page level saying the site has changed). This works fine when I’m directly running the view in the designer (just logging with - logger.warn("Sending Message from site select" + str(currentValue)) ).
I then have another project which inherits the CORE, and I include the site dropdown as an embedded view. Now, when I select a site from the dropdown, nothing happens at all - it seems the onchange is no longer getting called at all.
Am I doing something wrong here? Is there another way to pass messages up from inherited embedded components that I’m missing?
Jay
