We have a page where we perfomr a query through a button via script:
if event.source.parent.getComponent('CheckBox').selected ==True:
aadate=str(event.source.parent.getComponent('Popup Calendar').date)
maxdate=datetime.datetime.strptime(aadate, '%a %b %d %H:%M:%S %Z %Y')
#If checkbox not enabled use current time
else:
maxdate=time.strftime('%Y-%m-%d %H:%M:%S')
Now when i perform this query as the first thing when i startup the developer i get the following error:
ValueError: time data did not match format: data=Fri Sep 26 00:48:45 CEST 2014 fmt=%a %b %d %H:%M:%S %Z %Y
(is it me or does the str match the format?)
This happens on the line:
However:
a)when i execute another (similar-)query and after that come back to the query above it performs as expected…
b) i just started up the designer and performed the query, as expected i got the error message, then just waited a while (didn’t alter a thing) and performed the query again, second time no error it performed as expected…
Is this a bug? Does performing another (select-) query alter some sort of magical data i can not comprehend?
Could anyone help me with this issue??
