I’m trying to programmatically change the Min and Max Date variables of my X-Axis in a Chart. (based on a user date selection) The property panel says that they have a property scripting name of “minimumDate” and “maximumDate” but I don’t know how to change them via a script.
Easiest way is to put a DateRange control on the window and then tie the MinDate and MaxDate properties to the .StartDate and .EndDate of the DateRange control.
You can also do this with 2 calendar controls as well.
Yeah I tried to do that but I can’t figure out how to bind the date range properties because the Chart’s MinDate and MaxDate aren’t exposed in the properties window.
Thank you, I have it bound to tag history and I can see where to bind the date properties now. I was expecting it to be in the properties window but I was just looking in the wrong place turns out.
