Various port in different projects is possible
Hi
we have a two project one is for monitoring and other one accessing and controlling so for security purpose we have to give a separate port for each project, so is that possible means someone plz guide me and help me to sort the issue
Ignition can’t do that. You’ll have to use Ignition’s roles and user security to enforce your security rules.
thanks for the reply pturmel.
Port forwarding:
In computer networking, port forwarding or port mapping is an application of network address translation (NAT) that redirects a communication request from one address and port number combination to another while the packets are traversing a network gateway, such as a router or firewall. This technique is most commonly used to make services on a host residing on a protected or masqueraded (internal) network available to hosts on the opposite side of the gateway (external network), by remapping the destination IP address and port number of the communication to an internal host.[1][2]
Do you think, port forwarding can be more safer until Ignition releases a solution for the problem?.
