We have just upgraded our gateway to Ignition 7.6.4 and are now seeing lots of XML parse exceptions.
I’m not sure if this is due to a change to the way Ignition reports errors, or if it’s specific to these errors, but rather than giving popups these errors are just appearing in red in the console.
Here are some examples of the most regular ones…
We have this one when a table gains focus:
[Fatal Error] :1:1: Content is not allowed in prolog.
org.xml.sax.SAXParseException: Content is not allowed in prolog.
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1231)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
at com.inductiveautomation.factorypmi.application.components.table.ColumnAttributesMap$ListParser.fromXML(ColumnAttributesMap.java:254)
at com.inductiveautomation.factorypmi.application.components.table.ColumnAttributesMap.handleListOfStringColorPair(ColumnAttributesMap.java:136)
at com.inductiveautomation.factorypmi.application.components.table.ColumnAttributesMap.doConversion(ColumnAttributesMap.java:71)
at com.inductiveautomation.factorypmi.application.components.table.ColumnAttributesMap.<init>(ColumnAttributesMap.java:44)
at com.inductiveautomation.factorypmi.application.components.PMITable.setColumnAttributesData(PMITable.java:1054)
at com.inductiveautomation.factorypmi.application.components.PMITable.setColumnAttributesData(PMITable.java:1044)
at sun.reflect.GeneratedMethodAccessor188.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateTarget(AbstractPropertyAdapter.java:314)
at com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter.updateTarget(CellUpdateAdapter.java:213)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateValue(AbstractPropertyAdapter.java:258)
at com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter.eval(CellUpdateAdapter.java:182)
at com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter.eval(CellUpdateAdapter.java:120)
at com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter.access$000(CellUpdateAdapter.java:29)
at com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter$1.run(CellUpdateAdapter.java:205)
at com.inductiveautomation.ignition.client.util.EDTUtil$ProcessQueue.run(EDTUtil.java:110)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:666)
at java.awt.EventQueue.access$400(EventQueue.java:81)
at java.awt.EventQueue$2.run(EventQueue.java:627)
at java.awt.EventQueue$2.run(EventQueue.java:625)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:636)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
We have these when running deserialisation in our code export script:
java.lang.NullPointerException
at com.inductiveautomation.factorypmi.application.components.table.ColumnAttributesMap$DoubleDimensionParser.fromXML(ColumnAttributesMap.java:318)
at com.inductiveautomation.factorypmi.application.components.table.ColumnAttributesMap.handleDoubleDimension(ColumnAttributesMap.java:148)
at com.inductiveautomation.factorypmi.application.components.table.ColumnAttributesMap.doConversion(ColumnAttributesMap.java:68)
at sun.reflect.GeneratedMethodAccessor942.invoke(Unknown Source)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:68)
at com.inductiveautomation.factorypmi.application.xmlserialization.ComponentDeserializationHandler.endSubElement(ComponentDeserializationHandler.java:93)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementEnd(XMLDeserializer.java:663)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:165)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:313)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:233)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:209)
at sun.reflect.GeneratedMethodAccessor910.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
<snip>
[Fatal Error] :1:1: Premature end of file.
org.xml.sax.SAXParseException: Premature end of file.
at com.inductiveautomation.factorypmi.application.components.table.ColumnAttributesMap$DoubleDimensionParser.fromXML(ColumnAttributesMap.java:325)
<snip>
I am well aware that this is probably due to some specific data in our resources, but any hints as to what might be causing this would be much appreciated. Have there been any changes to the parser or XML format in 7.6?
Thanks.
Simon
