Version 8.1 upgrade from 3
Ok so we are in the process of upgrading from a very old version FSQL and FPMI to ignition 8.1, most of my transaction groups work fine, but for some reason the one block group does not. I have attached it here. One of two things happens when i attempt to run this transaction block group, either it does work but it constantly adds new rows upon new rows, or it comes up with the error message: can not start group invalid use of the fetch command. I went back to version 3 to check to make sure everything was as it should be and it seems identical so i am not sure what this error indicated because i do not think i used the fetch command in my SQL.
What this group does is it connects a DB, in this case progmode1, to several block OPC items, and when one of the items changes it triggers the block group. And like i said in one setting when i have it set to insert new records it does just that and keeps adding to the database, and when i have it set to use the where clause and use custom, which is what is used in FSQL, it comes up with the error: can not start group invalid use of fetch. and when i use the update first it does not always complete and when i use the other command of update only changed it sometimes comes up with the fetch error.
So should i just move to 8.3 or is there a simple easy fix that i am over looking?
prodtrack_2025-10-28_0632.zip (4.9 KB)
You should contact support as a first step.
One potential pitfall with an upgrade across this many versions is that I'm not sure which version of the JDBC drivers you'll end up. If your code happened to be working on the old one and we upgraded it "underneath you", that could cause issues.
