Version Notes of Reporting Module
Does someone know where I can see notes any version from any module?
I want to use a Report Viewer on Perspective, but the component won't appear.
I saw a post about that, and someone said it is an error from an old version of the module.
If is there any change between versions I don't want to cause a conflict in the programs for any function that has changed or has been removed.
The version currently being used is
Reporting 5.0.8 shipped with Ignition 8.0.8: Archived Ignition Releases | Inductive Automation
You might be able to use a later version from 8.0 successfully; it looks like the report viewer component was added to the reporting module in Ignition 8.0.10/Reporting 5.0.10.
But you're using an Ignition version that is officially unsupported and has been out since February 2020. It's got significant known issues. You should really plan to migrate to the latest 8.1 release as soon as possible.
Thank you! :slight_smile:
