Vertical Label
How can I have a vertical label ? I tried the rotation property but text is also inverted… need a mirror to read then :wink:
Should I use image ? no…
I tried using html and formatted the text like this: L
a
b
e
l
It worked fine. Not sure where your text is coming from, but if it’s dynamic, it’ll be easy to do this in scripting.
A really simple label. Drop a label on the window and simply change rotation property.
