Is it possible to have a vertical table with heading in a column?
It would only be 2 columns: Header and data.
Or any suggestions?
Thanks in advance!
-W
Or any suggestions?
Thanks in advance!
-W
Not quite really with the normam table unless heavily breaking css xD
Your best bet is flexrepeaters
and maybe some css grid styles?
Is there a reason you can’t use the Table component and only define one column?
True you could also just use the table component, disable header and construct two columns like header/data xd
Probably easier to get the default look that way xD
I actually misunderstood the question. to have a header on the side, you would need to construct your own container/view.
root (flex container in row mode)
L_ Label
L_ Flex Repeater (where each "row" is a new instance)
If you're willing to do some custom theming, I believe @thewebpleb has created an exchange resource with some CSS that accomplishes this. Granted, his version only displays the table's columns inside each cell when the view is shrunk past a certain breakpoint (e.g. mobile). It probably wouldn't be hard to define a custom table style class based on his css that would always format the table data in this manner though. Check out the following video at about the 11 minute mark:
