Thank you, Kevin for a quick reply.
Initial Java Heap Size (in MB)
wrapper.java.initmemory=256
Maximum Java Heap Size (in MB)
wrapper.java.maxmemory=3200
We have solved RAM usage problem with getting Gateway backup and restoring it right after. Now after running for a while, the java.exe takes 900mb which is a good enough.
Thanks.
One more feedback: there is something with expression tags. They are not being executed properly. DB tags return bad status with “no database defined” error, but actually it IS defined. After modifying them twice (make some difference and then return back), they start to work preperly.
