Vessel visualization error when upgrading to 8.1.16
I have discovered that the Vessel symbol has stopped displaying correctly since I updated to version 8.1.16 (starting from a version 8.1.14).
The vessel level is displayed outside the tank perimeter, offset below its actual value. (Attached image)
I’m not sure if it’s a bug or if I did something wrong during the update as in a “clean” install seems to work properly.
Any help on how to fix it would be appreciated!
Apparently there’s an (as yet undiagnosed) case where Perspective’s symbols fail to update cleanly. Support (support.inductiveautomation.com) can guide you through the process of making sure they update properly.
I have ticket #45056 for this issue. I shared your response to see what next steps are.
I also have this problem in 8.1.21
But ok when horizontal.
icons.zip (150.6 KB)
My problem was solved with the release of 8.1.18 but haven't tryed upgrading to 8.1.21.
A workarround I found prior to the release of the correction was to get the .svg files from a clean install and replace them in the path "\data\modules\com.inductiveautomation.perspective\icons " and then restart the gateway. Hope it helps!
