View global scripts, queries, and Perspective/Vision open simultaneously?
Is there a way to simultaneously view global scripts or named queries and perspective/vision windows at the same time?
Example of a current situation: I may be working on a named query or a global script that is used on a screen (Perspective or Vision). Right now I can't view the script or query at the same time as the screen (I can only view one or the other).
The only current workaround I see is opening two separate designers, it seems like overkill.
Float the script tab. Right click and select float all.
