View only user on client
Hello,
Is it possible to make a user that only has rights to view the screen?
I have a client who didn’t set up the security level’s like they should have.
At the moment the option “Inherit Permissions” is not used at all.
Do I have an option to skip this? Where for example there is a user that has “read-only” mode but not read-write.
I was thinking about making a user “ReadOnly”. Then I would edit a client-event script to say
if: u"ReadOnly" in roles:
system.util.setConnectionMode(2)
else:
system.util.setConnectionMode(3)
I got this from site below;
https://docs.inductiveautomation.com/display/DOC/Setting+Client+Read-Only
I’m just making sure if there is an easier way to do this?
Thanks in advance!
Any information on this?
I tried the following but it does not work:
Client script on tag value change
On tag change: [System]Client/User/Username i call script
project.Security.ReadOnly()
Scrip Readonly
def ReadOnly():
name = system.security.getUsername()
if name == ‘User’:
else:
Any ideas how i get a read only user?
I just did it in Client Events - Startup
if system.tag.readBlocking(['[System]Client/User/RolesString'])[0].value == 'ReadOnly':
	system.util.setConnectionMode(2) #2=ReadOnly
else:
	system.util.setConnectionMode(3) #3=ReadWrite
