View Tag Definitions
Is there a way to view all of my tag definitions. I have a ton of OPC tags and I want to go through and see if there are any duplicates. They’re all in this one folder, so I could probably script it to go through and get the OPC path as a list but I’m thinking even simpler than that.
I tried to copy the JSON and paste into excel, but it doesn’t look like the OPC path is copied with the JSON.
These tags are part of a UDT if that matters.
Use the tag report tool to export everything, add the OPC item path as a column, use Excel or w/e to crosscheck?
May need some guidance on how exactly to use the tool. Haven’t used it before. I was expecting this to get all tags (any quality) in the “East” folder that are type OPC. I get no results
You need a * wildcard in your tag path. East/*, perhaps.
