To sum up, my question is this: why the script does not work in the invisibile component’s component to make the component visible?
Here is the details:
I have a Template named AToggleBit with a Multi-State Indicator (MSI) component inside. The MSI has 3 states:
0 = Error
1 = OK
2 = Unused
And then in the MSI, on propertyChange event, I create a script like this (note that this is my whole script):
[code]if event.propertyName == ‘state’: #if the state changes
stateValue = event.source.state #get the current MSI state Value
atogglebit = event.source.parent #get the template
rcont = atogglebit.parent.parent.parent #get the Root Container (please don’t bother the triple parent here, the rcont is obtained this way)
if rcont: #if root container found
ddown = rcont.getComponent(‘Dropdown’) #get Dropdown in the Root Container
if ddown: #if dropdown found
ddval = ddown.selectedValue #get the Dropdown Value
#check template visibility
visibility = stateValue == 0 or \
(stateValue == 1 and ddval != 2) or \
ddval == 0
#just printing the values
print "[", ddown.selectedStringValue, "] state: ", \
"alarm" if stateValue == 0 \
else "normal" if stateValue == 1 else "unused", \
" visibility: ", visibility
#assign template visibility
atogglebit.visible = visibility #change the visibility of the template
[/code]
What the script in the MSI does is essential to show or to hide the AToggleBit Template.
Moreover, the script is only useful when the Template AToggleBit is placed in a Window with a Dropdown directly under the Root Container and where the Dropdown has following three value-string pairs:
0 = "All"
1 = "Used Only"
2 = "Active Only"
The script checks the Dropdown value and have the following visibility behavior:
Visible if:
- Its MSI is in “Error” (stateValue = 0), or
- Its MSI is “OK” (stateValue = 1) and the Dropdown value is NOT “Active Only” (ddval != 2), or
- The Dropdown choice is “All” (ddval = 0)
The Template AToggleBit is invisible otherwise. Thus we got the following code:
ddval == 0
Then, I also have script in the Dropdown to do the reverse. That is, to choose between the three options: “All”, “Used Only”, and “Active Only” - and to show the AToggleBit Templates according to the choice:
All -> Show all AToggleBit
Used Only -> Show all used or active AToggleBit (stateValue = 0 or stateValue = 1)
Active Only -> Show only active AToggleBit (stateValue = 0)
Now, here is the problem.
Naturally we have the following possibilities in the actual application:
- The Dropdown value is changed
- The MSI state in the AToggleBit is changed
In either case, I want the AToggleBit visibility to be consistent with the Dropdown value. However…
The script runs well, but only under the following conditions:
- The Dropdown value is not changed while the MSI state is changed, or
- The Dropdown value is changed but the AToggleBit is still shown when the Dropdown is changed. For example, when the MSI state in the AToggleBit is “OK” (stateValue = 1) and the Dropdown is changed from “All” to “Used only” -> The AToggleBit is still visible. The behavior is consistent
However, once:
- the Dropdown value changes, and it changes the AToggleBit’s visibility to False
- while the Dropdown value remains, the MSI state in the AToggleBit is changed to something that should be visible under this rule (for instance, stateValue = 0):
[code]visibility = stateValue == 0 or
ddval == 0
[/code]
BUT the AToggleBit remains invisible! That is, once is it invisible, no matter what happen to its child component (MSI state changes), it remains invisible still! I check using print in the code to ensure that the child component’s (MSI’s) script is run -> It is run. Furthermore, the visibility value of the script is correct (True). And the component atogglebit is also assigned correctly. THERE IS NO ERROR AT ALL – but it is just the AToggleBit does not become visible although the script shows the assignment very clearly:
Why is this so?
