Visibility of containers in Ignition Vision
Hello!
How is possible for me to see the different pages or containers inside an Vision Window, it seem the pages on the top cover the ones under on the Project Browser, so I can´t check the actual design of them.
Thanks!
I believe what you are saying is that you have multiple "groups" on a single window and you would like to work with those that are lower in the z-order.
In the designer you can toggle the visibility of the container from the properties. If you can not directly select the container then you can select it from the project browser.
If that isn't what you're asking, can you provide some more detail as to what your issue is?
Yes, that´s what I looking for.
the problem I´m having is that I can´t find this visibility option.
On the property editor there is a filter drop down. You currently have it set for basic, you need to set it for All properties.
progress
Oh, great Irose, this is it, thanks a lot for the motion capture, really helpful!
