Visible Binding - Using Expression type binding to search for key word in string
I have a drop down that is populated the following query.
SELECT '%' AS Value,"Select Container"
UNION
Select CONCAT_WS(' ', style, type) AS Value, CONCAT_WS(' ', style, type) AS Label
FROM container
ORDER BY Value ASC
Based on the operators selection of this dropdown I would like to Make Visible( or invisible) other objects on the screen. By looking for key words, in this case the word Can or Bottle.
If it was a query I would search for ‘%Can%’.
What is the best way to accomplish this goal?
This should work as your visibility expression (no match = -1):
indexOf({Dropdown.selectedValue}, "Can") > -1
The Drop down Selection I made is 12oz Standard Can
The Visible Binding is
indexOf({Root Container. Dropdown.selectedValue}, "Can") > -1
Nothing became visible and no errors.
Yeah, selectedValue should be selectedLabel or selectedStringValue–I’m guessing the former (or looking closer at your query, I expect either one will give the same result).
Perfect. Thank you.
Here is what appears to be working.
