Vision - Adding blinking feature into expression for border color
I have a basic script to switch border color given an integer value change. I’d like to add a feature where if a certain event occurs in the system, I can make the border color blink. This would need to occur only while the variable is equal to 1 and the event occurs. Script would otherwise remain normal where values = solid colors.
toBorder(
  "line;" +
  switch(
    {[default]PLC/INTERNAL/OVERVIEW/STARTUP TREE/INIT_STARTUP ROUGHING PRESSURE},
    0, 1, 2, 3,
    "0,0,0,255",      // black
    "255,153,0,255",  // yellow
    "0,204,51,255",   // green
    "255,0,0,255",    // red
    "0,0,0,255"       // fallback: black
  ";2"
Use a custom property and custom styles. Much easier and it will animate.
More info on the style customizer (absolutely the way to go here):
