I was using the Vision AdHoc Trend from Ignition Exchange in Ignition 8.1, but after upgrading to Ignition 8.3 I noticed that the Axes Table and the axes column in the Pens Table no longer work correctly. When I configure the axes in the Axes Table, the changes don’t update in the Pens Table. In addition, I can’t modify the axes directly in the Pens Table—the dropdown is empty and the column keeps showing “Unknown.”
Anyone here facing similar issue?
I use a modified version of the adhoc trend in all my projects, but I haven't made the jump to 8.3 yet as I'm waiting on more bugs to be flushed out before I make the jump. Since this is an exchange resource, you'll probably have to dig into it to see how that table is built and modify it to work with 8.3.
were you able to get the Vision AdHoc Trend working for Ignition 8.3. Facing similar issue here.
I recently worked with support and there's a fix coming in 8.3.10 that fixes some of the issues (8.3.9 and below I believe are messing up some of the datasets on the pens, so I was able to load the 8.3.10 nightly to fix everything then imported it into 8.3.9, but you can't open/modify it otherwise it breaks it all again.)
