Hello
I have a Vision project with a UDT for each type of device. Each device has a popup for it's UDT. The popup has a custom property (DevicePath) to pass a string path to the UDT instance.
First Question:
Should I create another custom property (Device) in the root container that is of the UDT type for that popup, and then do a single indirect binding on that to the instance of the UDT using the path that was passed in. Or should I just do indirect bindings througout the popup using the DevicePath property.
If I add the Device property, then I would do property bindings throughout the popup, otherwise, I would do indirect bindings througout the popup.
Follow up question:
If I add the Device property, should I treat it as read/write and write to the tags through the properties, or treat it as readonly and still do tag writes with system.tag.writeAsync() in button presses using the DevicePath property.
