Vision Chart - Category Chart & XTrace
Hey folks,
TL:DR - Looking to add some xtrace function to Vision "Chart" component in "Category" mode. I expect this ask falls squarely into "java wizardry," but would appreciate any advice on how to proceed.
Working with the Vision Chart component, using the "Category Chart" setting to display monthly values with an average over the top of it, showing year to year usage variance.
I am looking to add some x-trace functionality so users can click on a point on the chart and get the data back for the nearest month (or whatever function can nearest approximate this).
It appears as though the "Show Popup" menu does not work in Category Chart mode, and with that, x-trace is unavailable. "Selection Enabled" also appears to not work. "Show Tooltips" shows this less-than-helpful bit of information.
I've tried scripting some xtrace functionality following Justin's advice, but to no avail. Following jpark's advice I am able to get values for one of the two datasets. However, this falls apart when I add additional subplots.
Corresponding datasets for reference:
So, this post from lrose and this one from Travis were very helpful in getting something working on the chart with only the category bars.
from org.jfree.chart import ChartMouseListener
from org.jfree.chart.annotations import CategoryTextAnnotation
chartObject = self
class CustomChartMouseListener(ChartMouseListener):
	def chartMouseMoved(self,e):
		pass
	def chartMouseClicked(self,e):
		# Get plot, remove previous annotations
		plot = chart.getPlot()
		plot.clearAnnotations()
		# get chart data & create annotation
		if e.getEntity():
			# Get dataset(s)
			dataset = chartObject.b_MonthlyWater
			colNames = dataset.getColumnNames()
			ds = system.dataset.toPyDataSet(dataset)
			# Wrap in try to prevent error clicking on axis
			try:
				# Get category from entity
				category = e.getEntity().columnKey
				for row in ds:
					if row[0] == category:
						rData = (row[1], row[2])
						y = max(rData)+100 #offset so annotation is above tallest bar
				# Add annotation
				annoStr = str(colNames[1])+": "+str(int(rData[0]))+", "+str(colNames[2])+": "+str(int(rData[1]))
				plot.addAnnotation(CategoryTextAnnotation(annoStr, category, y))
			except:
				pass
# Ensure only 1 listener running
for listener in self.getListeners(ChartMouseListener):
     self.removeChartMouseListener(listener)
# Run listener
self.addChartMouseListener(CustomChartMouseListener())
A couple outstanding issues:
  • Adding the xy category overlay breaks the function, and clicking on the chart will not produce annotations.
  • Documentation suggests the annotations will support HTML, but as of yet I've been unable to produce a multi-line entry.
Will update as I progress.
How's this going?
Pretty much no progress since last post. I tried a couple alternate approaches to rendering the x-trace, but to no avail.
I left off having Category Bar annotations, but introducing the Category XY plot on top of the bar chart returns only the last data point for the XY plot at any given point (which is usually NaN due to the nature of the graph).
I ran into a skills wall, and with that ran out of free time to focus on this. The lack of experience with java is really killing me here. I can read the docs on the jfreechart and associated components all day and still not understand how properly to apply them. :upside_down_face:
I'm hoping to circle back after the backlog is reduced.
Wanna upload an example window? I'm off the next couple of days, so it's possible I could find some time to take a look at it.
Can't say no to that! I've included 2 version of the chart.
"Chart Scripting" is the simplified chart I am using to test my scripting efforts to place an x-trace on the screen. With both plots enabled, it will not work (just shows December from the Category Line Renderer). Working with only the bar chart, the script should populate x-trace.
"Chart Export" is the complete chart I'd like to produce. Pie-in-the-sky goal is x-trace that shows values on all charts when any of the 4 subplots is clicked.
Please let me know if you have any questions.
ChartExport_2025-04-07_1031.zip (41.9 KB)
How about this?
It works like a traditional x-trace with or without subplots
WWChartDemo-1
WWChartDemo-2
It simply uses my glass pane example to render the custom x-trace information
Here is the library script that is needed for the overlay:
GlasspaneLibraryScripts.zip (3.7 KB)
...and here is the modified chart window:
xTraceCategoryChart.zip (31.5 KB)
Oh wow, this is amazing. Well beyond the scope of my ability to tackle the issue. Also a great reference for the power of the paintable canvas.
I owe you a couple beers at this point.Thank you so much!!
It's true. Once one of these is in place, adding custom functionality becomes really simple. Check out this idea I had for highlighting the xTraced data points:
WWChartDemo-3gif
To do this, I added a custom method to the xTrace Pane called paintDataHighlights:
def paintDataHighlights(self, graphics, entities):
	from java.awt import BasicStroke
	graphics.stroke = BasicStroke(4)
	for entity in entities:
		graphics.color = system.gui.color(255, 255, 0, 100)
		if entity.size:
			graphics.fillRect(entity.location.x, entity.location.y, entity.size.width, entity.size.height)
			graphics.color = entity.foreground
			graphics.drawRect(entity.location.x, entity.location.y, entity.size.width, entity.size.height)
		else:
			ovalRadius = 6
			ovalDianmeter = 2 * ovalRadius
			graphics.fillOval(entity.location.x - ovalRadius, entity.location.y - ovalRadius, ovalDianmeter, ovalDianmeter)
			graphics.drawOval(entity.location.x - ovalRadius, entity.location.y - ovalRadius, ovalDianmeter, ovalDianmeter)
Then, I added a size parameter to the xtraceLabel class in the getXTraceLabels custom method:
	from java.awt import Point # for storing coordinate data
	from java.awt import Dimension # For storing length and width properties
	# Create a class to package up all the information into easy to use fields
	class xtraceLabel():
		def __init__(self, text, foreground, location, size):
			self.text = text
			self.foreground = foreground
			self.location = location
			self.size = size
Additionally, the xTraceLabels.append line at the end of the method was changed in the following way:
# Don't store dimensional data for points
if hasattr(entity.area, 'currentPoint'):
	size = None
# Store the height and widht of each bar chart bar
else:
	size = Dimension(int(entity.area.width), int(entity.area.height))
# Create an instance of the xtraceLabel class, store the extrapolated data in it, and add it to the labels list
xTraceLabels.append(xtraceLabel(text, foreground, location, size))
Finally, this line of code was added just before the paintXTraceLabel call in the repaint event handler to call the paintDataHighlights custom method:
event.source.paintDataHighlights(event.graphics, plotLabels)
