Vision client error, empty project
Hi, I'm having some troubles with while launching a project in vision, I'm getting the following error:
Whether I open it from designer or vision client launcher, the error still the same, I already tied erasing the .ignition/cache folder, re installing the whole client launcher but nothing seems to work, The project is just fine because i can open it from other computers, mine is the problem and seems like a vision client problem because I can perfectly reach the gateway and the perspective app of the same project
I tried everything as admin also but got no results, also tried opening the app by cmd using:
C:\Users\Admin\.ignition\cache\resources\runtimes\11.0.15\bin\java.exe -classpath C:\Users\Admin\.ignition\cache\resources\platform\launchclient.jar\00000000244C47CF\launchclient.jar -Djavaws.sr.gateway.addr.0=https://myapp.ignition.com:443 -Djavaws.sr.launchts=1740577347162 -Djavaws.sr.main=com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms256M -Xmx1024M -Djavaws.sr.memory.init=256M -Djavaws.sr.memory.max=1024M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=C -Djavaws.sr.project=RoesleinOEE com.inductiveautomation.ignition.client.launch.BootstrapSwing
and this is what I get:
Microsoft Windows [Version 10.0.19045.5487]
(c) Microsoft Corporation. All rights reserved.
C:\Users\Administrator> C:\Users\Administrator\.ignition\cache\resources\runtimes\11.0.15\bin\java.exe -classpath C:\Users\Administrator\.ignition\cache\resources\platform\launchclient.jar\00000000244C47CF\launchclient.jar -Djavaws.sr.gateway.addr.0=https://myapp.ignition.com:443 -Djavaws.sr.launchts=1740577347162 -Djavaws.sr.main=com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms256M -Xmx1024M -Djavaws.sr.memory.init=256M -Djavaws.sr.memory.max=1024M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=C -Djavaws.sr.project=MainOEE com.inductiveautomation.ignition.client.launch.BootstrapSwing
Starting Bootstrap Loader v3.0
Connect Step [attempt 1] connecting to: https://myapp.ignition.com:443...
Downloading manifest at https://myapp.ignition.com:443/system/launchmf/C?os=windows&arch=x64
...connect successful
Successfully downloaded launch manifest:
<?xml version="1.0" encoding="UTF-8"?>
<launch scope="C" framework="7" jreVersion="11.0.15" useCondensedDialogFont="false">
        <module name="" build="2022072711">
                <jar name="synthetica-addons-3.4.1.jar" crc="677F89ED" length="266776"/>
                <jar name="miglayout-core-4.2.jar" crc="FEECEF57" length="66663"/>
                <jar name="timingframework-1.0.jar" crc="7832C4C0" length="102616"/>
                <jar name="commons-collections4-4.4.jar" crc="6847F0D3" length="751914"/>
                <jar name="common.jar" crc="CA3FD312" length="3818471"/>
                <jar name="jul-to-slf4j-1.7.26.jar" crc="BF2AD0D0" length="4589"/>
                <jar name="commons-lang3-3.11.jar" crc="4FD4C07C" length="577742"/>
                <jar name="xmlgraphics-commons-2.3.jar" crc="CAE5A1BA" length="671727"/>
                <jar name="poi-ooxml-4.1.1.jar" crc="5C3A1400" length="1859884"/>
                <jar name="bcprov-jdk15on-1.69.jar" crc="A76F4870" length="5743920"/>
                <jar name="bcutil-jdk15on-1.69.jar" crc="76A0656E" length="359496"/>
                <jar name="jxbrowser-swing-7.12.1.jar" crc="A75EF1E7" length="141749"/>
                <jar name="swingx-0.0.3-ia.jar" crc="65E602E1" length="1512564"/>
                <jar name="cron4j-2.2.5.jar" crc="FFAC5F7B" length="36227"/>
                <jar name="curvesapi-1.06.jar" crc="D1B9BE33" length="111875"/>
                <jar name="slf4j-api-1.7.26.jar" crc="A71DAC84" length="41139"/>
                <jar name="jydocking-3.4.1.jar" crc="5EC6B4CE" length="281641"/>
                <jar name="jgrapht-core-1.4.0.jar" crc="AB8E765E" length="1091677"/>
                <jar name="kotlin-stdlib-jdk8-1.5.31.jar" crc="BC25B1B7" length="16121"/>
                <jar name="common-image-3.8.2.jar" crc="4B0CF8FF" length="85550"/>
                <jar name="commons-compress-1.19.jar" crc="19AE5191" length="615064"/>
                <jar name="ia-gson-2.8.5.jar" crc="7F980716" length="261492"/>
                <jar name="kotlin-stdlib-common-1.5.31.jar" crc="4DB332A5" length="198322"/>
                <jar name="forms-1.0.7.jar" crc="5E8CB029" length="86828"/>
                <jar name="poi-ooxml-schemas-4.1.1.jar" crc="8F7A32A" length="7884238"/>
                <jar name="bcpkix-jdk15on-1.69.jar" crc="15FDAC12" length="909020"/>
                <jar name="imageio-batik-3.8.2.jar" crc="C3BA9D31" length="21567"/>
                <jar name="batik-swing-1.12.jar" crc="B83D4C3E" length="190772"/>
                <jar name="jide-common-3.7.4.jar" crc="DC3DB1B" length="1632900"/>
                <jar name="common-lang-3.8.2.jar" crc="9D303406" length="119561"/>
                <jar name="log4j-over-slf4j-1.7.26.jar" crc="5296FF81" length="23650"/>
                <jar name="joda-time-2.10.2.jar" crc="EE76ABA0" length="642711"/>
                <jar name="kotlinx-coroutines-core-jvm-1.5.2.jar" crc="1FB63442" length="1481065"/>
                <jar name="batik-awt-util-1.12.jar" crc="4CEB277F" length="422448"/>
                <jar name="batik-util-1.12.jar" crc="F09002E9" length="127209"/>
                <jar name="logback-classic-1.2.3.jar" crc="6407A406" length="290339"/>
                <jar name="jytable-3.4.1.jar" crc="AEC20C93" length="168130"/>
                <jar name="client-bootstrap-8.1.19.jar" crc="86E085FC" length="4032839"/>
                <jar name="kotlinx-coroutines-swing-1.5.2.jar" crc="DDF67DE4" length="9331"/>
                <jar name="batik-script-1.12.jar" crc="73865109" length="25715"/>
                <jar name="active-query-builder-8.1.19.jar" crc="C840C584" length="2641511"/>
                <jar name="commons-codec-1.13.jar" crc="1F1614BB" length="344339"/>
                <jar name="commons-math3-3.6.1.jar" crc="5D5A24E1" length="2213560"/>
                <jar name="batik-bridge-1.12.jar" crc="7F6DB498" length="695968"/>
                <jar name="java-cup-10k.jar" crc="3FCB2D3D" length="84156"/>
                <jar name="synthetica-3.4.2-beta1.jar" crc="4E398ECC" length="621708"/>
                <jar name="commons-logging-1.2.jar" crc="3621FD43" length="61829"/>
                <jar name="guava-26.0-jre.jar" crc="47C422DD" length="2740721"/>
                <jar name="batik-gvt-1.12.jar" crc="83F7136" length="191437"/>
                <jar name="commons-text-1.9.jar" crc="89FA2468" length="216211"/>
                <jar name="jxbrowser-7.12.1.jar" crc="8B8D0FBE" length="9877025"/>
                <jar name="jxbrowser-win64-7.12.1.jar" crc="7CDBF04A" length="61843697"/>
                <jar name="poi-4.1.1.jar" crc="5964EDEF" length="2827712"/>
                <jar name="batik-css-1.12.jar" crc="CD9AE2F4" length="325399"/>
                <jar name="batik-dom-1.12.jar" crc="E51605CA" length="182590"/>
                <jar name="jose4j-0.7.12.jar" crc="97E622F1" length="277563"/>
                <jar name="batik-xml-1.12.jar" crc="10A9F179" length="33497"/>
                <jar name="kotlin-stdlib-1.5.31.jar" crc="8C0FD528" length="1505952"/>
                <jar name="kotlin-stdlib-jdk7-1.5.31.jar" crc="CDCCB4BF" length="22986"/>
                <jar name="core-java6-3.2.1.4.jar" crc="B87C35C4" length="543804"/>
                <jar name="jfreechart-min-1.0.0.jar" crc="DC0AEE96" length="1636824"/>
                <jar name="httpcore-4.4.13.jar" crc="2FCEAFE7" length="328593"/>
                <jar name="httpclient-4.5.13.jar" crc="EC26836C" length="780321"/>
                <jar name="miglayout-swing-4.2.jar" crc="DA98AC37" length="14580"/>
                <jar name="jyiconfonts-3.4.1.jar" crc="17C9D3E3" length="1141225"/>
                <jar name="ignition-laf-3.1.0-beta13.jar" crc="EF05BC26" length="406791"/>
                <jar name="jheaps-0.11.jar" crc="67F79D2" length="133503"/>
                <jar name="commons-io-2.2.jar" crc="11E1D2AE" length="173587"/>
                <jar name="barcode4j-2.1.jar" crc="B907C79" length="274404"/>
                <jar name="annotations-13.0.jar" crc="E6DD8E33" length="17536"/>
                <jar name="xml-apis-1.3.04.jar" crc="9F219AB6" length="194354"/>
                <jar name="logback-core-1.2.3.jar" crc="D9BC8F47" length="471901"/>
                <jar name="xml-apis-ext-1.3.04.jar" crc="87389C28" length="85686"/>
                <jar name="batik-transcoder-1.12.jar" crc="169E104E" length="128581"/>
                <jar name="imageio-core-3.8.2.jar" crc="B0F39B58" length="91636"/>
                <jar name="batik-constants-1.12.jar" crc="188FD9CD" length="8271"/>
                <jar name="jide-plaf-9-0.0.1.jar" crc="83F57046" length="195573"/>
                <jar name="jython-ia-2.7.2.1.jar" crc="A5AE7F4C" length="33892008"/>
                <jar name="batik-parser-1.12.jar" crc="B8AD1229" length="76504"/>
                <jar name="batik-svg-dom-1.12.jar" crc="2502C887" length="231948"/>
                <jar name="batik-svggen-1.12.jar" crc="E2CD27B5" length="224908"/>
                <jar name="jide-grids-3.7.4.jar" crc="141BFEB0" length="2322572"/>
                <jar name="batik-ext-1.12.jar" crc="D8C7ED74" length="10075"/>
                <jar name="client-api-8.1.19.jar" crc="A1B33D89" length="3179100"/>
                <jar name="commons-cli-1.4.jar" crc="57B55D77" length="53820"/>
                <jar name="batik-i18n-1.12.jar" crc="ECB4E1A" length="11263"/>
                <jar name="jide-components-3.7.4.jar" crc="FD5B5C01" length="403617"/>
                <jar name="xmlbeans-3.1.0.jar" crc="87DB6FAA" length="2579738"/>
                <jar name="xalan-2.7.2.jar" crc="8C752A59" length="3154938"/>
                <jar name="jywidgets-3.4.1.jar" crc="4C211D0A" length="494288"/>
                <jar name="batik-anim-1.12.jar" crc="BEF50792" length="479193"/>
                <jar name="common-io-3.8.2.jar" crc="8571C25C" length="90059"/>
                <jar name="serializer-2.7.2.jar" crc="EC00A0FF" length="276420"/>
                <jar name="launchclient.jar" crc="244C47CF" length="4698137"/>
                <jar name="metrics-core-4.2.0.jar" crc="EDDA5463" length="125973"/>
        </module>
        <module name="com.tamakicontrol.modules.plantreplay" build="2020111920">
                <jar name="__3616565966__plantreplay-designer-1.8.5-SNAPSHOT.jar" crc="91891311" length="32554"/>
                <jar name="__3616565966__plantreplay-common-1.8.5-SNAPSHOT.jar" crc="C22064DE" length="11546"/>
                <jar name="__3616565966__plantreplay-client-1.8.5-SNAPSHOT.jar" crc="32477E71" length="57559"/>
        </module>
        <module name="com.inductiveautomation.serial-support-client" build="2022072711">
                <jar name="__1398296126__serial-support-client-6.1.19.jar" crc="85AF73F2" length="3091"/>
                <jar name="__1398296126__serial-support-common-6.1.19.jar" crc="5A42FDF9" length="15681"/>
                <jar name="__1398296126__jSerialComm-2.6.2.jar" crc="16F610F3" length="469932"/>
        </module>
        <module name="com.inductiveautomation.alarm-notification" build="2022072711">
                <jar name="__1988767375__alarm-notification-client-6.1.19.jar" crc="A36D00DB" length="56922"/>
                <jar name="__1988767375__alarm-notification-common-6.1.19.jar" crc="8AEA283D" length="25033"/>
        </module>
        <module name="productiongateway" build="2012171725">
                <jar name="__3850075689__productioncommon.jar" crc="D767049B" length="3364469"/>
                <jar name="__3850075689__analysisengine.jar" crc="2994CE31" length="668015"/>
                <jar name="__3850075689__mesignitioninterface.jar" crc="9906F0AE" length="70359"/>
        </module>
        <module name="qualitygateway" build="2012171725">
                <jar name="__2625441495__mesignitioninterface.jar" crc="9906F0AE" length="70359"/>
                <jar name="__2625441495__qualitycommon.jar" crc="8D7327C3" length="1487524"/>
        </module>
        <module name="oeedt2gateway" build="2012171725">
                <jar name="__1505753454__oeedt2common.jar" crc="24C99D86" length="453356"/>
                <jar name="__1505753454__mesignitioninterface.jar" crc="9906F0AE" length="70359"/>
        </module>
        <module name="com.inductiveautomation.vision" build="2022072711">
                <jar name="__2199203620__vision-client-11.1.19.jar" crc="2FC4F490" length="3180728"/>
                <jar name="__2199203620__vision-common-11.1.19.jar" crc="6BBE1540" length="13389"/>
        </module>
        <module name="instrumentgateway" build="2012152209">
                <jar name="__1831888041__mesignitioninterface.jar" crc="825018C" length="70359"/>
                <jar name="__1831888041__parsecommon.jar" crc="7CC86DB8" length="360054"/>
        </module>
        <module name="com.inductiveautomation.opcua" build="2022072711">
                <jar name="__735638082__opc-ua-common-9.1.19.jar" crc="CDADA512" length="2072"/>
                <jar name="__735638082__opc-ua-client-9.1.19.jar" crc="1F9A4886" length="5603"/>
        </module>
        <module name="com.inductiveautomation.sqlbridge" build="2022072711">
                <jar name="__767338295__sql-bridge-common-10.1.19.jar" crc="1402A837" length="114160"/>
        </module>
        <module name="com.inductiveautomation.reporting" build="2022072711">
                <jar name="__1013400735__poi-3.14.jar" crc="107E735E" length="2528204"/>
                <jar name="__1013400735__reporting-client-6.1.19.jar" crc="69E7A473" length="2775894"/>
                <jar name="__1013400735__reporting-common-6.1.19.jar" crc="FB8115F3" length="3526355"/>
                <jar name="__1013400735__icepdf-viewer-6.3.2.jar" crc="9D046453" length="1232244"/>
                <jar name="__1013400735__icepdf-core-6.3.2.jar" crc="C56894E2" length="1440836"/>
                <jar name="__1013400735__bcprov-ext-jdk15on-1.69.jar" crc="4E8CAC61" length="5814235"/>
        </module>
        <thirdPartyModules md5="29225bc83f30fa2135b7128197332d1b"/>
        <connect usessl="true" port="8043"/>
</launch>
Claiming id in C:\Users\Administrator\.ignition\cache\gwmyapp.ignition.com_443...
... obtaining lock
... lock obtained.
... claimed id 1
Calculated necessary downloads:
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        <thirdPartyModules md5="null"/>
</launch>
Third party Python modules downloaded.
Downloading "https://myapp.ignition.com:443/system/translations/"...
Connect successful.
Starting download of -1 bytes
Download attempt #0 for translation database failed.
com.inductiveautomation.ignition.client.launch.steps.ValidationException: Number of bytes received does not match content-length header. (8907 != -1)
        at com.inductiveautomation.ignition.client.launch.steps.DownloadTranslationsStep.download(DownloadTranslationsStep.java:119)
        at com.inductiveautomation.ignition.client.launch.steps.DownloadTranslationsStep.run(DownloadTranslationsStep.java:27)
        at com.inductiveautomation.ignition.client.launch.AbstractStepRunner.run(AbstractStepRunner.java:33)
Connect successful.
Download attempt #1 for translation database failed.
Connect successful.
Download attempt #2 for translation database failed.
Creating classloader with JAR files: [i omitted this bc of the caracter allowed in the post]
Starting class: com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by de.javasoft.plaf.synthetica.SyntheticaLookAndFeel (file:/C:/Users/Administrator/.ignition/cache/resources/platform/synthetica-3.4.2-beta1.jar/000000004E398ECC/synthetica-3.4.2-beta1.jar) to method sun.swing.DefaultLookup.setDefaultLookup(sun.swing.DefaultLookup)
WARNING: Please consider reporting this to the maintainers of de.javasoft.plaf.synthetica.SyntheticaLookAndFeel
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
10:47:30.937 [secure-random-seed-gen] INFO Common.SecureRandomProvider - Secure random seed generated in 2ms
10:47:30.968 [Thread-0] INFO com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook - Ignition Client v8.1.19 (b2022072711)
10:47:31.671 [Thread-0] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Initializing gateway connection with URLs: [https://myapp.ignition.com:443]
10:47:31.687 [Thread-0] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - SSL enabled.
10:47:32.359 [Thread-0] WARN Localization.ClientLocalizationManager - The translation term database does not exist.
10:47:32.359 [Thread-0] INFO com.inductiveautomation.ignition.client.util.gui.progress.ClientProgressManager - Progress manager started.
10:47:33.093 [Thread-0] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Skipping local challenge - directory doesn't exist.
10:47:33.203 [Thread-0] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Updated login state. Logged in? true, Username: eum1008, Roles: [HomePageAccess], Security Zones: null
10:47:33.640 [Thread-0] INFO com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook - Auto-login successful
Creating frame. extendedState=6, bounds=java.awt.Rectangle[x=0,y=0,width=1920,height=1080]
10:47:33.687 [ProjectDownloader] INFO Vision.DownloadProjectPane - Downloading "https://myapp.ignition.com:443/data/vision/client/project/MainOEE"...
10:47:34.653 [ProjectDownloader] INFO Vision.DownloadProjectPane - Connect successful.
10:47:34.653 [ProjectDownloader] INFO Vision.DownloadProjectPane - Starting download of -1 bytes
10:47:34.653 [ProjectDownloader] ERROR Vision.DownloadProjectPane - Error downloading or decoding full project.
java.lang.IllegalArgumentException: Negative initial size: -1
        at java.base/java.io.ByteArrayOutputStream.<init>(Unknown Source)
        at com.inductiveautomation.factorypmi.application.runtime.DownloadProjectPane$DownloadProject.downloadProject(DownloadProjectPane.java:330)
        at com.inductiveautomation.factorypmi.application.runtime.DownloadProjectPane$DownloadProject.initProject(DownloadProjectPane.java:163)
        at com.inductiveautomation.factorypmi.application.runtime.DownloadProjectPane$DownloadProject.run(DownloadProjectPane.java:111)
com.inductiveautomation.ignition.client.launch.steps.ValidationException: Cannot start empty project.
        at com.inductiveautomation.factorypmi.application.runtime.DownloadProjectPane$DownloadProject.initProject(DownloadProjectPane.java:173)
10:47:34.669 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.client.util.gui.ErrorUtil - null
Any suggestion to solve this?
PD. I leave the entire output from cmd in a file bc the post character limit
logs.txt (38.1 KB)
Given these two messages:
Connect successful.
and that it works on other computers... I think you have an IT/network issue. There's probably a firewall or some network security appliance interfering with the download.
It was the DNS server, I have static IP config and IT department changed the DNS server and didn't tell me, Thanks a lot !
:smiley:
