Hi colleagues, I'd like some help, please.
I have two PCs to use and practice with Ignition. On the first, I have six projects stored in the Getway, and on the second PC, I want to open those projects using the Vision Client Launcher. The problem is that on the second PC, out of six projects, it only shows me five to open. Why is this? Am I missing some additional configuration in the project that isn't showing me? I attach images.
Are they all vision projects? Can you open all 6 in the designer?
To be specific - do they have at least one Vision window in them?
Ya encontré mi error, por lo que me di cuenta, debo agregar el proyecto en Getway y también en el diseñador.
Lo hice de manera correcta y resultó.
Por otro lado también estaba intentando abrir un proyecto de Perspective con visión client Launcher.
Problema corregido, gracias por su ayuda.
(machine translation)
I've found my mistake. As far as I know, I need to add the project in Getway and also in the designer.
I did it correctly, and it worked.
On the other hand, I was also trying to open a Perspective project with the Vision Client Launcher.
Problem fixed, thanks for your help.
