Vision Client Launcher Issue with Duplicated Project Description
I am using version 8.1.1 with an updated vision client launcher. The client launcher appears to duplicate 1 project description across all other projects within a gateway. Below are two different gateways with a description copied for every project.
The descriptions show correctly when adding the application, but not when added.
Yes, we had the identical issue with version 8.1.1 client launcher on Windows. The description for the first project on the gateway is copied to all project shortcuts added to client launcher.
Thanks for reporting, I opened a ticket so somebody will look into this.
I am having the same issue, which occurred after I added and subsequently renamed the newly added project.
It looks like the fix for this will be available in 8.1.3.
