Vision Client Launcher - Shortcut Error
For some reason the shortcut for one of our projects isn’t working. I’m not sure what would cause that or what would’ve changed. It was working. But the error I get is:
Launch Error
Project could not be found on the gateway
If I launch from the vision client launcher it loads fine.
What OS are you on? Did you modify the settings for the project in the Vision Client Launcher at all after creating the shortcut? One thing that immediately comes to mind is if you renamed it in the Vision Client Launcher after creating a shortcut.
If you recreate the shortcut do you get the same error?
Thanks,
Jonathan C
Thanks I think we got it figured out. The project we used we may inheritable about a week ago. I think that was problem. Didn’t pickup on it as I was just using the launcher.
