Vision Client Launcher
I am a new user to Ignition and am learning the tool.
I have 2 projects running on the gateway. The 2nd project was created recently. The designer sees both the projects right away when I launch it. However, when I open the vision client launcher and try to add an application, it only displays the project prior to the newly created one.
Not sure if I'm doing anything wrong.
You'll have to add any new projects manually, as they don't automatically show up in the client launchers when you add them to the gateway.
You might also have to ensure that there's at least one Main Window in the project for it to be eligible to start.
Thank you for the reply.
Yes, I already tried adding the project manually. But it does not list the projects available on the gateway.
When I click Add Application>Select Gateway> Project list.
Here in the project list, it still does not show the new project.
Also, I have created a main window and have couple of tags reading data to indicator components.
You can't launch an inheritable project either.
Thank you very much,
Its working now.
The first time I unchecked inheritable and updated the project, it still was not opening in the client.
However after I restarted the gateway, it seems to be working.
And yes, the project should "NOT" be inheritable.
