Vision Client Limit on Ignition Edge
Hello all. Does anyone know if there is a limit to the number of Vision Client Launcher windows for projects on an Ignition Edge gateway? A client reported having trouble opening a third window.
Yes, it’s two maximum, and one MUST run on the gateway. With Edge Perspective, you can run two max remote from the gateway.
If you need more, standard Ignition is the only option.
I see, thank you
Forum tip: if you don’t require further advice on this matter you can click “solution” =)
