Vision Client not displayed
I'm having trouble because the Vision Client is not showing up.
(Environment)
Windows11 Pro 24H2 26100.6584
Chrome 140.0.7339.186
Ignition8.3
(Question)
The manual for Gateway states that the Vision menu should appear in the Home menu, but it does not appear in my Gateway environment. Furthermore, it is also not shown under Home > Downloads.
I thought that perhaps Vision was not installed during the Ignition installation, so I checked, and for some reason, the Vision option was not checked. However, even after reinstalling with the Vision option checked, the situation did not change.
What could be the reason why it is not displayed?
Thanks in advance!
Maker Edition doesn't support Vision - only Perspective.
If you're evaluating or doing test development you should be using the regular version of Ignition and just resetting the trial every 2 hours.
Thank you!
I wasn't aware of the restrictions of the Maker Edition. I will try using the regular edition.
