Line 22 of my script calls a named query and gives me the below error.
The data actually writes fine into the database but my vision client is unhappy and errors out - rest of script doesn't execute.
This is line 22
system.db.runNamedQuery("Build/WriteBuildData", parameters)
If I test the named query - same deal, data writes fine but com.microsoft.sqlserver.jdbc.SQLServerException: The statement did not return a result set.
An insert doesn't return a result set, right?
INSERT INTO tbl_build_data (hvc_sn, kitID, pack_sn, pack_type, station_id, stepComment, stepComplete, stepID,tech_id)
VALUES (:myhvc_sn, :mykitID, :mypack_sn, :mypack_type, :mystation_id, :mystepComment, :mystepComplete, :mystepID, :mytech_id)
23:59:06.051 [AWT-EventQueue-0] ERROR c.i.i.client.util.gui.ErrorUtil - <HTML>Error executing script for event: <code><b>actionPerformed</b></code><BR>on component: <code><b>ConfirmWICompl</b></code>.
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last):
File "<event:actionPerformed>", line 22, in <module>
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:334)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:967)
at com.inductiveautomation.factorypmi.application.db.namedqueries.ClientNamedQueryManager.execute(ClientNamedQueryManager.java:32)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities.runNamedQuery(ClientDBUtilities.java:118)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.microsoft.sqlserver.jdbc.SQLServerException: The statement did not return a result set.
at org.python.core.Py.JavaError(Py.java:545)
at org.python.core.Py.JavaError(Py.java:536)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:192)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
at org.python.core.PyObject.__call__(PyObject.java:477)
at org.python.core.PyObject.__call__(PyObject.java:481)
at org.python.pycode._pyx831.f$0(<event:actionPerformed>:30)
at org.python.pycode._pyx831.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1703)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:804)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:207)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:300)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
at jdk.proxy2/jdk.proxy2.$Proxy54.actionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: org.python.core.PyException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.microsoft.sqlserver.jdbc.SQLServerException: The statement did not return a result set.
... 51 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.microsoft.sqlserver.jdbc.SQLServerException: The statement did not return a result set.
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
... 48 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayResponse$GatewayThrowable: com.microsoft.sqlserver.jdbc.SQLServerException: The statement did not return a result set.
at com.inductiveautomation.ignition.gateway.db.namedquery.NamedQueryExecutor$NamedQueryInstance.execute(NamedQueryExecutor.java:407)
at com.inductiveautomation.ignition.gateway.db.namedquery.NamedQueryExecutor.execute(NamedQueryExecutor.java:173)
at com.inductiveautomation.ignition.gateway.db.namedquery.GatewayNamedQueryManager.execute(GatewayNamedQueryManager.java:95)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.NamedQueryFunctions.execute(NamedQueryFunctions.java:49)
at jdk.internal.reflect.GeneratedMethodAccessor93.invoke(null)
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(null)
at java.lang.reflect.Method.invoke(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:228)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:435)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:523)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:598)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1580)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1553)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
at org.eclipse.jetty.server.Server.handle(Server.java:563)
at org.eclipse.jetty.server.HttpChannel$RequestDispatchable.dispatch(HttpChannel.java:1598)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:753)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:501)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:287)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:421)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:390)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:277)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.run(AdaptiveExecutionStrategy.java:199)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
at java.lang.Thread.run(null)
