VISION - Create a Dark Mode Popup Calendar
I've been trying to create a Dark Mode Popup Calendar, and i ran into this problem right here, i cannot change the colors of these specific parts of the popup calendar, how can i do that? is that even possible? i've been searching everywhere and i did not find anything about it :sob:
The cool thing about Vision is that anything's possible. It's just a question of whether or not the maintenance costs are worth it.
These two handy utility functions are the product of my years of digging stuff out of Vision components:
# Returns the first nested component of a given class
# container = The object containing nested components to be recursively searched
# className = the __name__ of the class given as a string
def getComponentOfClass(container, className):
	for component in container.components:
		if component.__class__.__name__ == className:
			return component
		else:
			foundComponent = getComponentOfClass(component, className)
			if foundComponent:
				return foundComponent
# Returns all nested components of a given class
def getAllComponentsOfClass(container, className):
	foundComponents = []
			foundComponents.append(component)
		else:
			foundComponents.extend(getAllComponentsOfClass(component, className))
	return foundComponents
The dropdown arrow is a JButton, so using my utility script, getting it from the popup calendar for direct manipulation can be done in this way:
popupCalender = event.source
dropdownButton = getComponentOfClass(popupCalender, 'JButton')
dropdownButton.background = system.gui.color('grey')
Result:
Modifying the down arrow is trickier because it's an icon, but icons of this nature are easy to make. Creating and applying a single character icon looks like this:
from javax.swing import Icon
class WhiteDownArrow(Icon):
	# https://docs.oracle.com/javase/8/docs/api/javax/swing/Icon.html
	# Arguments = (Component c, Graphics g, int x, int y)
	def paintIcon(self, c, g, x, y):
		g.setColor(system.gui.color('white'))
		g.drawString(unicode('▾'), 6, 13) # X and Y coordinates set using trial and error
	def getIconWidth(self):
		return 14
	def getIconHeight(self):
		return 14
dropdownButton.icon = WhiteDownArrow()
Result:
Getting the internal JButtons and JSpinner from the calendar itself is problematic because first you have to get the calendar. Looking through my notes on this component, it looks like the only way I've found to get that is through reflection. However, once the popup calendar has been obtained, the buttons and JSpinner can be retrieved using my utility scripts in this way:
popupButtons = getAllComponentsOfClass(popup, 'JButton')
spinner = getComponentOfClass(popup, 'JSpinner')
However, when I try to change the color on the JButtons, something in that component overwrites the change when the popup is subsequently launched. An easy way to get around this is to simply add a property change listener to the buttons that will maintain the color
Packaging this all together in a propertyChange script for the dropdown, it ends up looking like this:
# Assumes there is a boolean custom property on the popup calendar called 'isDarkMode',
# ...that is used to toggle the dark mode theme on an off
if event.propertyName == 'isDarkMode' and event.newValue:
	from java.beans import PropertyChangeListener
	# Maintains the color of JButtons embedded in a hidden popup menu
	class DarkModeColorListener(PropertyChangeListener):
		def propertyChange(self, event):
			if event.propertyName == 'background' and event.newValue != black:
				event.source.background = black
			elif event.propertyName == 'foreground' and event.newValue != white:
				event.source.foreground = white
	# Creates a white replacement icon for the popup calendar dropdown button
			g.setColor(white)
			return 14
			return 14
				return component
			else:
				if foundComponent:
			else:
	# Assign the colors to variables for use everywhere in the script
	black = system.gui.color('black')
	white = system.gui.color('white')
	# Get the dropdown JButton, change its background color and give it a white icon
	dropdownButton = getComponentOfClass(event.source, 'JButton')
	# Get the popup calendar from the dropdown using reflection
	popupField = event.source.getClass().getDeclaredField('popup')
	popupField.setAccessible(True)
	popup = popupField.get(event.source)
	# Get all of the jbuttons from the popup, change its colors, and add a listener to maintain them
	for button in popupButtons:
		if 'DarkModeColorListener' not in [listener.__class__.__name__ for listener in button.propertyChangeListeners]:
			button.addPropertyChangeListener(DarkModeColorListener())
		button.background = black
		button.foreground = white
	# Get the spinner component from the popup and directly manipulate its colors
	spinner.background = black
Result:
For reference, these were the Appearance parameters used during this test:
Since I foresee this being used on multiple popup calendars throughout a project, I believe that it would make sense to store this in the project library. If this were wrapped up in a function called setPopupCalendarDark and the function were nested in a library script called `componentScripts, it would look like this:
Library Script Example
			return component
		else:
			if foundComponent:
		else:
def setPopupCalendarDark(popupCalendar):
			g.setColor(white)
			return 14
			return 14
	dropdownButton = getComponentOfClass(popupCalendar, 'JButton')
	popupField = popupCalendar.getClass().getDeclaredField('popup')
	popup = popupField.get(popupCalendar)
Then, it could called by any popup calendar in this way:
	componentScripts.setPopupCalendarDark(event.source)
This approach also frees up the utility scripts to be called from anywhere using their library script paths.
Can't underscore this enough.
I almost tagged you directly, Justin, but figured you wouldn't be able to resist the challenge once you saw this thread :joy:
I implemented the library script example and it works (almost). When I am in the designer and I toggle the isDarkMode value and run the calendar in the designer has the correct colors. However when I launch the client, it never works. I tried both examples the component script version and the library version. Both behave the same way. I am not sure how to fix it. Any ideas? I can send screenshots of the calendar if that would help.
Sorry, I misread which thread we were in
No worries, did my reply make sense? I noticed that the issue was solved for the original poster but in my case, it doesn't seem to work fully. The calendar looks right in dark mode but the time background isn't working. I don't fully understand how the script works so I cant fix it.
:grimacing: I hope you're working on fixing that, because :smiling_face_with_sunglasses: stuff like this comes with a maintenance cost that somebody needs to be able to pay.
Looking at the code, my guess is the project is likely getting saved with isDarkMode already set to True, so the propertyChange event doesn't get triggered when the client launches. A propertyChange event will only occur if the property named in the if statement actually changes.
If this is going to be an always dark mode scenario, then componentRunning should drive it:
# Always dark in the client
if event.propertyName == 'componentRunning' and event.newValue:
However, if this is going to be a toggleable type thing, then the propertyChange event handler will need to account for both initialization and state changes in the custom property:
# Can be either dark or light
if event.propertyName in ['componentRunning', 'isDarkMode'] and event.source.isDarkMode:
:100:
This fixed the issue, thanks. I will always use dark mode, so the toggleable feature was unnecessary.
I agree, backdoor coding always has a maintenance cost. I am not a big fan of fixing things this way. If the component was designed properly in the first place this type of fix would not be required.
I have created a support ticket to see if the developers will fix the calendar component in the future.
