This looks like a bug in Vision ezChart.
For an EZChart Axis dataset when I bind using cell update on row 0 to a component like a text box the binding gets bound to row 1 when the axis dataset is loaded from a script.
Is this a bug or am I doing something wrong?
See cell update binding below:
So when I load dataset into the axis property
components that are bound to row 0 actually get bound to row 1
components that are bound to row 1 actually get bound to row 2
etc.
See below:
However, If I put data into the component so it will write a value to the ezChart, all the bindings go to the correct order, that is.
components that are bound to row 0 actually get bound to row 0
components that are bound to row 1 actually get bound to row 1
etc.
I am running Ignition 8.1.12.
Here is the code:
I have a button btn0_PresetLoad with ActionPerformed event handler with this code:
logger = system.util.getLogger("Vision.Components.Button0")
s_logPfx = event.source.name + ".actionPerformed"
logger.trace(s_logPfx + " --->")
#logger.debug(s_logPfx + " --- ")
cmpnt.btn0.onActionPerformed(event)
cntnr_Root = system.gui.getParentWindow(event).getRootContainer()
cntnr_Parent = event.source.parent
dropdL0_Chart = event.source.parent.getComponent("dropdL0_Chart")
i_chart = dropdL0_Chart.selectedValue
ds_chart = dropdL0_Chart.data
pds_chart = system.dataset.toPyDataSet(ds_chart)
s_tmplt = pds_chart[i_chart][2]
dropdL0_Filter = event.source.parent.getComponent("dropdL0_Filter")
i_filter = dropdL0_Filter.selectedValue
ds_filter = dropdL0_Filter.data
pds_filter = system.dataset.toPyDataSet(ds_filter )
dropdL0_Grp = cntnr_Parent.getComponent("dropdL0_Grp")
i_grp = dropdL0_Grp.selectedValue
s_grp = dropdL0_Grp.selectedStringValue
s_dsktpHandle = system.gui.getCurrentDesktop()
logger.debug(s_logPfx + " --- " + " s_dsktpHandle: " + s_dsktpHandle)
if system.gui.desktop(s_dsktpHandle).confirm("Are you sure you want to load preset %s?" %(s_grp), "Confirm"):
logger.debug(s_logPfx + " --- " + " loading preset %s begin" %(s_grp))
s_wndwMain = cntnr_Root.CurrentWindow
logger.debug(s_logPfx + " --- " + " s_wndwMain: " + s_wndwMain)
try:
wndw_Main = system.gui.desktop(s_dsktpHandle).getWindow(s_wndwMain)
except ValueError:
wndw_Main = None
if wndw_Main is not None:
cntnr_Main_Root = wndw_Main.getRootContainer()
tmplt = cntnr_Main_Root.getComponent(s_tmplt)
cntnr_Tmplt_Root = tmplt.getComponent(0)
ezChrt0_ = tmplt.getComponent(0).getComponent("ezChrt0_")
b_error = False
s_txId = system.db.beginTransaction(timeout=5000)
try:
#Tag Pens
if i_filter == 0 or i_filter == 1:
s_tbl = "tbl_chart_tag_pen"
logger.debug(s_logPfx + " --- " + " s_tbl: " + s_tbl)
pds_1 = event.source.loadDSfrTable(s_txId, s_tbl, i_grp)
ds_1 = system.dataset.toDataSet(pds_1)
ezChrt0_.tagPens = ds_1
#DB Pens
if i_filter == 0 or i_filter == 2:
s_tbl = "tbl_chart_db_pen"
i_rows = len(pds_1)
ezChrt0_.pens = ds_1
#Calc Pens
if i_filter == 0 or i_filter == 3:
s_tbl = "tbl_chart_calc_pen"
ezChrt0_.calcPens = ds_1
#Axes
if i_filter == 0 or i_filter == 4:
s_tbl = "tbl_chart_axes"
ezChrt0_.axes = ds_1
ds_axes = ds_1
for r in range(ds_axes.getRowCount()):
cntrn0_VAxis = cntnr_Tmplt_Root.getComponent("cntnr0_0Main").getComponent("cntnr0_VAxis" + str(r))
if cntrn0_VAxis is not None:
b_auto_range = ds_axes.getValueAt(r, "auto_range")
mSBtn0_Axis_Auto = cntrn0_VAxis.getComponent("mSBtn0_Axis_Auto")
if mSBtn0_Axis_Auto is not None:
mSBtn0_Axis_Auto.controlValue = b_auto_range
f_lower_bound = ds_axes.getValueAt(r, "lower_bound")
nTFld0_Axis_Min = cntrn0_VAxis.getComponent("nTFld0_Axis_Min")
if nTFld0_Axis_Min is not None:
nTFld0_Axis_Min.floatValue = f_lower_bound
f_upper_bound = ds_axes.getValueAt(r, "upper_bound")
nTFld0_Axis_Max = cntrn0_VAxis.getComponent("nTFld0_Axis_Max")
if nTFld0_Axis_Max is not None:
nTFld0_Axis_Max.floatValue = f_upper_bound
#SubPlots
if i_filter == 0 or i_filter == 5:
s_tbl = "tbl_chart_subplot"
ezChrt0_.subplots = ds_1
except:
raise
b_error = True
if b_error:
#Error encountered, rollback the transaction
system.db.rollbackTransaction(s_txId)
logger.debug(s_logPfx + " --- " + " loading preset %s cancelled" %(s_grp))
else:
#No Error encountered, commit the transaction
system.db.commitTransaction(s_txId)
logger.debug(s_logPfx + " --- " + " loaded preset %s completed" %(s_grp))
tmplt = wndw_Main.rootContainer.getComponent(s_tmplt)
tFld0_Title1 = tmplt.getComponent(0).getComponent("cntnr0_0Main").getComponent("tFld0_Title1")
if tFld0_Title1 is not None:
tFld0_Title1.text = "Preset " + s_grp
# In either case, close the transaction when we're done.
system.db.closeTransaction(s_txId)
else:
logger.trace(s_logPfx + "<--- ")
The important part of actionPerformed event handler is:
#Axes
The button has this custom method
def loadDSfrTable(self, x_txId, s_tbl, i_grp)
Arguments:
self: A reference to the component instance this method is involed on. This arguement
is automatic and should not be specified when invoking this method.
s_logPfx = self.name + ".loadDSfrTable"
ary_col_MD_map = database.get_DS_DB_map(s_tbl)
s_sql_header = dataset.pyDataSetToStrForSelQryHeader(ary_col_MD_map)
s_sql = "SELECT %s FROM %s WHERE grp_id = %d ORDER BY ds_ord" %(s_sql_header, s_tbl, i_grp)
logger.debug(s_logPfx + " ---" + " s_sql: " + s_sql)
pds_1 = system.db.runQuery(s_sql)
i_rows = len(pds_1)
logger.debug(s_logPfx + " ---" + " i_rows: " + str(i_rows))
return pds_1
Any help appreciated.
-Mark
