Vision hide window "close" button
Hello everyone, I have a problem.
I want to hide my vision client’s title “close” button and “zoom out” button
Can do it?
I try use Vision Client Launcher,but it without about the function.
In Vision Client Launcher if you select the project → Manage → Windows Mode you can choose to open the project as full screen.
I try it,but I still need my window can free drag.
If choose full screen, I will lost it.
or have other of ways to do it?
Ah ok, I’m sorry I can’t help about this
Nope, one or the other.
I was playing with this and I can’t understand why .setResizable works and .setDefaultCloseOperation doesn’t…
from javax.swing import SwingUtilities
root = SwingUtilities.getRoot(event.source)
root.setResizable(False)	#THIS WORKS
root.setDefaultCloseOperation(root.DO_NOTHING_ON_CLOSE)	#THIS DOESN'T WORK
I know that .setDefaultCloseOperation will not disable the close (X) button like .setResizable, but it should prevent closing the window… or not?
I don’t know about .setDefaultCloseOperation, but if you want to intercept the closure of the Application, you can use the Client Event Script Shutdown-Intercept
You can use event.cancel=1 to prevent the application from being closed.
This is useful if you want to make a popup to appear to confirm the application shutdown.
This won’t make the (X) button disappear, but maybe this can help you, I hope :slightly_smiling_face:
Yes, thank you... :+1:
I know about shutdown-intercept...
It's not about closing application.... well, not in my case...
I just wanna know why
works and
don't...
What about just turning off the closeable property on the window in designer -
yields
Edit: Oh I see this is for main windows.
Maybe my case can do this way.
thank you!!
Maybe I can try it,
but my boss will kill me. lol
