Vision Image Management - Blurry when used in image
I have a high definition image that I am using in a vision project. The original image looks great in terms of quality. However, when I add the image to my image management folder and then use it in an 'image' component in vision, the resulting image in the project is blurry. Does anyone know how to make this image quality look better or look like in the original image? Thanks.
See attachments to see the difference of the original image and how it looks in vision.
In my opinion, such an image will always look a bit blurry when you scale it down or display it at a size that is not the original one.
I think the only way to properly keep your image clean is to use a SVG instead of a regular image.
