Vision Module Ignition 8.1.5 - TreeView Control runtime view scaling issue
We are moving to Perspective Module for this project, so the post was about something we moved away from… Thank you for you input.
What do you have the layout set to for the Tree View component? Also, a screenshot may help as it’s not clear if you are talking about the size of the component or the size of the text/icons inside of the component.
We moved away from the Vision Module to go all in with the Perspective- now a moot point, thanks for your feedback
