Vision Multi-State Indicator - window size of rows in the states
Is there a way to expand/stretch the window to see what is going on in the multi state indicator in vision better?
Particularly when there are two rows in one value set, I can't see it very well.
Also, not sure how to make more rows inside the states.
Are you talking about the styles dataset?
I will screenshot it later.
Or if you place a multi state indicator in version 8.1.19, the Fault value 3 has two rows partially visible.
I don't really know how the styles dataset works yet. I have to research that.
