Vision Project Image Path
Hello,
I have a Vision project that I'm migrating to Perspective. However, the image paths are missing because I'm now working on a different computer, not the main server. How can I locate the images using the original gateway or file explorer? Where does Ignition Vision typically store these images?
Thanks!
If you are using filesystem-based images, then you will need to deploy the images to all client workstations, using the same folder and file names.
If you are using Ignition's Image Management tool, then images are stored in the gateway's internal configuration database, not anywhere in the filesystem. You will have to manually load them into any new gateway.
Thanks @pturmel , I guess Ignition´s Image Management was used in this case because I searched for .png, .jpg... and couldnt find these images.
How could access them on the gateway to load into a new gateway?
You can export them through the Image Management Tool and then import them into the new gateway with the same tool.
