When editing in the designer, my screen looks as it always has. However, when the vision project is launched almost none of the templates are populated on the screen. This only happened to one window. Here are screenshots from the designer and the launched project.
You should contact support.
If there are no errors in the (client) logs, then I would suspect either A: component security settings set to hide these components, or B: a misconfigured binding on the visibility property.
