Vision: Set Cursor icon manually
I want to use an image in the Image Management area to set the cursor icon to, but when I set it to the image, the cursor disappears altogether. Am I getting the path wrong?
My image is stored in the Image Management under: Cursors/green.png
My code to set the cursor is:
from java.awt import Toolkit, Point
tk = Toolkit.getDefaultToolkit()
img = tk.getImage("Cursors/green.png")
c = tk.createCustomCursor(img, Point(event.source.parent.getX(), event.source.parent.getY()), "img")
event.source.parent.setCursor(c)
Thanks in advance
You seem to have neglected saying which version of Ignition, as in 7.9.11 or 8.03 that is in use. I have noted the .awt and would guess that the specific Java or Azure install would also be relevant. Post a response here, because I am guessing that the programmers look for number of participants before selecting questions to answer. For them, this should be easy with the information I requested… G’Day!
You will need to get the image like this:
from com.inductiveautomation.ignition.client.images import ImageLoader
img = ImageLoader.getInstance().loadImage("Cursors/green.png")
Awesome, thanks for the help! That works, although a minor correction, line 6 should use img and not myImage.
Cheers!
where is the code inserted? in Scripts > mouseEntered?
