Vision Symbol Factory to Perspective
I have some experience with vision, and now I'm working on a project involving perspective. I would like to use images from the Vision Symbol Factory in the Perspective project, since it seems that there is only symbol for motor, pump, sensor, valve and vessel built in perspective... How can I achieve this? Are there any SVG Symbol Factory images stored within the gateway installation files that I could add in the Image Management:
C:\Program Files\Inductive Automation\Ignition
Thank you!
There's nothing to stop you from using Symbol Factory in Perspective. You can drag symbols from Symbol Factory directly into a View. They are treated like any other imported SVG.
