Vision Tag Browse Tree Root Node Path on multiple Root
Is it possible to set the Root node Path of a Tag Browse Tree to multiple tag path?
Thank you,
No not multiple paths. It can only be a single Tag Path.
Assuming that part of the tag path is shared, then set the root to that path, then use the filter event to filter out any paths that you don't want to be browsable.
As another alternative, you can use the Tree View Component so you can build your own structure and customize it further.
