Vision trends and sparkline issue
Vision trends and sparkline doesn't show data when launching either in windowed or full screen mode. But when I see the screen in designer it shows data. Does any body knows what could be the possible reason for this issue?
I am using a SQLLite database connection which cis showing Status as Valid to store history data.
I have attached images showing these symptoms.
Sharad
Have you turned on legacy database permissions? (In the project security settings.) Database pens on an easy chart won't work without that permission.
Thanks a Lot Phil for your guidance on this. I had to enable Tag History under Project Properties to resolve this.
Thank You
Sharad
