I am trying to get the user management component working however I am running into issues. In the project properties I have the appropriate Roles entered to allow user management, but when I try to make a new user in my client, nothing gets saved. Thoughts?
Hard to know what may be the issue without more context. But a couple things to try are,
1: Have you checked your gateway settings to make sure the "Allow User Admin" box is checked under your general security settings?
2: Is your user management component set to "Manage users" mode?
If both of these answers are yes, then as long as you are logged in as a user with the appropriate role for user management then it should allow you to modify and save, or add new users.
It was the first question you asked, didn't realize that was a setting! Thanks!
No problem, glad to help!
